Prints some documents in wrong direction on paper. Could this be caused by the Print Driver? It has also printed like 2 inches of a blue print and stopped printing. Customer will have to unplug machine to get it to reset.
HP T730
Re: HP T730
I've seen whole cases of rolls that measure 36 1/16", and display that way on the panel and in the driver (36.1"). That's a mismatch for Arch C, Arch D, & Arch E prints. The funny part was that I had successfully guessed this over the phone for a billable customer. They did not believe me. The salesman brought out an actual 36" roll of paper that did read correctly and does size match. Then they wanted a refund for the paper that they bought from somebody else. What?? No. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Re: HP T730
Blackcat is absolutely right about the roll width. Though I thought HP put out a firmware update to deal with that?
And I believe in the driver there's an option for 'auto rotate'. I never recommend enabling this. Set the rotation to zero.
If you can post a picture of the 2 inches of blue, and knowing what they're trying to print (PDF, image, DWG,) might be helpful. Does the ink go from edge to edge of the paper or is there a border? Edge to edge means there could be something up with the printer; carriage or trailing cable perhaps. If there are borders then it's likely a driver issue, or communications issue. If it's a specific file they're printing, try rotating it 180 degrees and printing it, see if there's a difference.Comment
Re: HP T730
Re: HP T730
No, it shouldn't print edge to edge. If there is ink in the voids it's being smeared from something else. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Re: HP T730
I've seen printers print a swath constantly from the service station all the way across the media path and beyond. I think this is more of a fluke than anything else. I don't recall a printer doing it all the time and it needing a replacement of some part. If anything it just required a new printhead(s).
KiranComment
