HP Designjet T7100 paper error occurs
  • Profibastler
    • Nov 2014
    • 98
    Hello,
    can anybode help please?
    Designjet starts normal without problem.
    When initial is finish and open frontcover to change
    printhead, the carriage is working bad.
    The linear movement appears to be heavy,
    but the guidance is clean and oiled.
    If the carriage is moved by hand,
    there is no noticeable obstacle.
    Paper jam trouble is displayed.
    Please see movie also:
    The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
  • Kiran Otter
    • Dec 2013
    • 1106
    Re: HP Designjet T7100 paper error occurs
    Yikes. If I had to guess, the belt is either not installed at the back of the carriage correctly, or the back of the carriage is broken and allowing the belt to slip. Try moving the carriage while holding onto the belt and see if it slips. If it does, then check where it threads through at the carriage.
    And make sure the tensioner is fully tightened.
    Kiran
    • Profibastler
      • Nov 2014
      • 98
      The tensioner is spring-mounted and at the strongest level.
      The carriage can be moved quickly by hand without any problems.
      Could it be an Axis motor problem?
      • Kiran Otter
        • Dec 2013
        • 1106
        Make sure you can NOT move the carriage independent of the belt.
        Kiran
        • Profibastler
          • Nov 2014
          • 98
          Kiran
          Doesn`t slip and back of carriage is not broken. belt is correctly threads through the carriage. There`s nothing to fix.
          • Kiran Otter
            • Dec 2013
            • 1106
            Alright, thank you for verifying it's not the belt/carriage. I don't think the motor is at fault because in my experience they never fail, but that doesn't mean it's bad. But I would suspect it last. Can you run the carriage axis test and see what happens?
            Is there any excessive play in the carriage?
            Kiran
            • Kiran Otter
              • Dec 2013
              • 1106
              When was the belt replaced last? Is it a belt from HP or China?
              Kiran
              • Profibastler
                • Nov 2014
                • 98
                • Kiran Otter
                  • Dec 2013
                  • 1106
                  I would suspect the belt then if it's not genuine. It also appears to have a lot of slack in it based on the video. I would get a genuine belt first before throwing other parts at it.
                  Kiran
                    • 22999
                    Did you clean the timing pulley on the carriage motor. I've seen the rubber shavings from the old belt pack into the grooves of the timing pulley, making it slip. I don't think that I've ever seen a failed carriage motor. I've changed a few carriage motors, and it did not solve my issue. =^..^=
