I believe I have exhausted the things to check on this error. Trying to see if there's anything else I have missed. The rollers are good. The small gear on the feed unit is there and intact. The spring is in place. The solenoid absolutely not sticky. Firmware was updated. I have swapped the different trays around without getting any further. All the other trays will work and print. It's only tray 2. One sheet halfway out and one in path that are blank. I watched from the rear and it looks like the rollers are continuously spinning. I watched the solenoid, it looks like it's firing.
Has anyone heard of the paper feed drive causing a problem ? It was having a different problem I was looking at first. By the time I got to this part it was taking to long and I had to go to other calls, so I didn't get a chance to take that off & look at it.
I would greatly appreciate to hear if this rings any bells with anyone. Thanks.
