hp 8150 dirty pages
  • ComputerMonkey
    • Sep 2008
    • 69
    hp 8150 dirty pages
    ok so the first pages are fine in fact i can print a hundred pages fine but as soon as there is a lag between print jobs the back of my pages are dirty after ~15 pages it cleans up but once a new job is sent its back to absolutely filthy backs. front side of page is perfect
    pull cartage and the drum is partly coated but it clears when you rotate it
    charge roller is coated in toner.
    clean them and once its up and running any waiting jobs print perfect until there is a pause in the printing and its back to dirty grey backs
  • The Destroyer
    Road Warrior
    • May 2009
    • 17
    sounds to me you got a cheap knock off toner cartrige problem. stick with Hp cartriges only.
    • ComputerMonkey
      • Sep 2008
      • 69
      I'm a tech and the cartage works in my test machine at the office perfectly
      (side note)
      My company sells so called knock off printer cartages and we have a ~1% fail rate so dont blame generics just because they have been bad in the past
      • prntrfxr
        • 1622
        hp 8150 dirty pages
        Check contacts that touch cartridge, try new HVPS, or replace fuser. Toner is getting on the back of pages comes from dirty pressure roller, but that toner had to come from somewhere so try the first 2 suggestions first. Try to eliminate cause of toner buildup or you're going to have this problem again.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • ComputerMonkey
          • Sep 2008
          • 69
          toner on the back comes from the charge/transfer roller as it is totally coated when i pull the cartage
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            If one of your cartridges dumped on the transfer, it is having an effect. Change the transfer or at least try to clean it real good with a dry cloth and air. Then try a different cartridge, even if it is the same brand. The odds of two doing the same thing are small, if you know that they worked well in the past.
            • CanonHPTech
              • Apr 2007
              • 235
              I have seen knock-off cartridges go bad after half their rated life, I have seen good reman'd cartridges (MSE) that have defects shortly after install, I have seen brand new OEM cartridges bad out of the box.
              Bottom line, with out another cartridge (or another printer), you will never know if you have a known-good cartridge. I have assumed cartridges good because I didn't have one and all I did was waste time and throw good money away replacing good parts. Keep it simple. Don't forget it could be the Fuser. The fact that it is showing up after a run, sounds like something not cleaning itself. These Fuser do not have cleaning rollers like the same Fuser installed in its original Canon engine printer, so they depend on the Rollers to be coated correctly and correct pressure. Since it is not every time, I would suggest getting a new/different Toner and Fuser. Hell, you will need the replacement Toner Fuser (get the maintenance kit that comes with the Fuser and Transfer Roller so you can rule that out also) at some point anyhow, so it is only an investment not a extra cost. However, swapping other parts could prove to be a waste of time and money. Good luck. Post your results.
              The glass maybe half full, but less is more...
              Printer + Fax + Copier = Jack Of Many Trades,
              but Master Of None
              Color Copier = Not A Color Printer
              InkJet MFP = Not A Fax Machine
              B/W Copier = Not A Press
              Finisher = Deal Closer (salesman, not accessory)
              Copier Tech = Admin's Stress Ball (Scapegoat)
              • ComputerMonkey
                • Sep 2008
                • 69
                bad high voltage board
