HP 9000
  • Reed blowin in the wind
    • Jun 2025
    HP 9000
    Any body got any ideas on a hp 9000 mfp intermittantly blowing the fuse in the plug.Event log showing random jams in the finisher no other errors?.When working its running fine.Help please.
    • 23002
    Probably a dozen times over the years I've heard customers say that a copier or printer is blowing a fuse. Only once has it actually been a short in the copier (it was a Mita DC-152Z).
    Every other time it was an overloaded circuit, and the copier or printer was just the last straw. The worst of which was in a home office with only one circuit, which included 5 computers, various monitors, printers, shredders, a washing machine, and an electric dryer (and a Mita copier). A total of 95 amps of potential load. =^..^=
    • prntrfxr
      • 1622
      HP 9000
      9000's are known power hogs and must have a dedicated outlet. i've seen them display flaky things and were fine once power was cycled. Do not run them on a surge protector and try to make sure its the only thing on the circuit. The LVPS can go bad, main motor, and of course the infamous False 13.20 error (clear all sensors, if there's still a problem, replaced Fuser and DC Controller simultaneously). Other than those things I haven't seen too many problems. After a million pages examine cables harnesses carefully. I had to replace the harness that goes to the Laser Scanner.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
