hp 3050
  • Incredible1
    • 24
    hp 3050
    Hi everyone! I'm new to hp's. My tech is working on an hp 3050 when he manually enters an email address the @ symbol "beeps" but doesn't appear on the screen we, thought it was a bad op- panel and replaced it with the same result, we checked another 3050 that works correctly.
    I have the feeling that there is an answer to this in programming or something deceptively simple. All help will be greatly appreciated!!!!!!!!!!
    • 23002
    I don't know that panel, but could it be something simple like Shift + @, or Upper Case + @? Is the @ grayed out until some secondary key is pressed? =^..^=
    • Incredible1
      • 24
      tech reset control panel and fax ? then the @ became functional. (it wasn't greyed out before the reset.
      Thanks very much for your response!
