HI,
I replaced the fuser unit with new one,and worn drvie gear on idler that drives fuser.Other gear on frame that lifts paper tray is fine.T%he fuser stills grinds and vibrates and even knocks, AND KICKS OUT away from drive ,but still makes contact so it turns. When I put slight pressure on lower fpart of fuser,it runs SMOOTHLY ,,noise and vibration free. The blue fuser locks are new and in tact. Does the frame cutout they lock onto need to be bent in to lock tighter. If not what else can I try.This seems to be a fairly common problem on these machines as I have seen a number of them do this. ANY HELP WOULD BE APPRECIATED.
\ THANKS< ANDY
\ THANKS< ANDY
