HP 4000 TN
  • Machinercylr
    • Dec 2006
    • 73
    HP 4000 TN
    I have an HP 4000TN that started out with a dark print and eventualy started to print lighter (using OEM 27X Cartridges). The Fuser, ECB and a new 3rd party Transfer roller were installed. Laser/Scanner lens and mirrors were cleaned. And evened preformed a "half-test". The toner cartridges were printing Font pages from The Information part of the printer for test purposes. The top of the page that has a solid Black strip with the white block letters PS Font List on the left are truly dark the way it is intended to be about half-way to the right-hand part of the same image, it starts to get light and blotchy. Can it be the Laser/scanner itself? Is there a way to test the unit (laser/scanner)? Thanks<Steve
  • OMD-227
    From the Service Manual......
    Engine Test
    The printer has one test pattern (vertical lines). When an image
    defect appears, a test print can be made to identify the problem. The
    test print can be made by pressing the test print switch located on the
    left side of the printer.
    A test pattern can be printed by pressing the test print switch once after the
    photosensitive drum has stopped and the printer has entered the
    standby mode. If the switch is held down, the test pattern is printed
    continuously. The switch can be used when paper is loaded in any
    tray other than Tray 1.
    The Engine Test does the following:
    z
    Verifies that the print engine is functioning correctly (the
    Formatter PCA is completely bypassed during an engine test).
    z
    Is used for isolating printer problems.
    z
    Is used for checking and adjusting registration.
    z
    Prints from Tray 2, 3, or 4 only, not from Tray 1.
    z
    Can be activated with the Formatter PCA removed.
    Note
    For the printer to perform an engine test, Tray 2, 3, or 4 must be installed
    and loaded with paper, and the Toner Cartridge must be installed in the
    printer.
    Location of Engine Test Button
    The engine test button is located on the left side of the printer, below
    the fan vent,
    • Machinercylr
      • Dec 2006
      • 73
      I've performed as suggested
      I produced 4 samples and they all have the same void light line area on the trailing or bottom right side of the page...Stumped again Steve
      • OMD-227
        Any chance of scanning a sample page and attaching here?
        I dont know enough about the paper path design on the HP printers to offer any more advice. Been fortunate enough not to touch them over the years.
        • prntrfxr
          • 1622
          HP 4000 TN
          When you cleaned the laser scanner, did you physically remove it from the printer, open the top and clean the lenses? Check to make sure there are no obstructions in the shutter.
          Is the transfer roller even or is one end higher than the other? (If you do, then you might have a broken transfer roller clip, in which case you would need to replace the paper feed guide asm - see other post in HP forum for instructions) You could also have a defective transfer roller (even happens with OEM rollers)
          Check the HVPS contacts that touch the cartridge and make sure they are clean.
          Oh...and make sure economode is off.
          Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
            • 23010
            Great suggestions prntrfxr. I only have one thing to add.
            Check the protective light blocking shutter for the drum, on the toner cartridge. If it is hanging crooked it can block the light path from the laser causing light areas in your prints (all prints). In a pinch these light shutters can often be removed with no harmful consequences. The cartridge just needs to stay in the machine, away from room light. In most cases this is not a problem. =^..^=
