Hp4350 problem
  • nokia88
    • Aug 2009
    • 72
    Hp4350 problem
    Hi all,
    I have a Hp4350n, it's displayed: error 49,4C18. Can somebody help me ?
    Thanks.
  • prntrfxr
    • 1627
    "49.XXXX
    PRINTER ERROR
    To continue turn off then on
    A critical firmware error has occurred that
    caused the processor on the formatter to
    abort the operation.
    This type of error can be caused by invalid
    print commands, corrupt data, or invalid
    operations.
    In some instances, electrical noise in the
    cable can corrupt data during transmission
    to the printer. Other causes include poorquality
    parallel cables, poor connections, or
    specific software programs.
    Sometimes, the formatter itself is at fault,
    which is usually indicated by a 79 Service
    Error.
    After performing the actions above,
    procede with the following:
    1 Turn the printer on.
    2 If the error message disappears,
    reinstall each DIMM and EIO device
    individually, making sure to turn the
    printer power off and then on again as
    you install each device. To replace
    a DIMM, see Firmware DIMM
    (LJ 4200/4300 only).
    3 Replace the DIMM or EIO device that
    caused the error message.
    4 Remember to reconnect all of the
    cables that connect the printer to the
    network or computer.
    5 If this error message persists, replace
    the firmware DIMM. See Firmware
    DIMM (LJ 4200/4300 only).
    6 Replace the formatter assembly. See
    Formatter assembly ." - Service Manual
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • 22929
      Like she said.
      Corrupt print commands can cause this error. I had a situation where the corrupt job was stuck in the queue, and had to be cleared by the IT rep. Next, I'd reload the driver. Next, firmware. And lastly, formatter.
      • PEPELEMU
        Tech
        • Oct 2008
        • 38
        I had the same problem, updated firmware and still had problem, the changed the driver. If you are using pcl6 driver change it to pcl5. That is what fixed my problem.
