HP 4014N Fuser Code 50.7
  • Jose
    • Nov 2009
    • 9
    Printer has Fuser Code 50.7.
    I pulled a fuser from a working printer and tested in the bad one it still gave me the same code. I then took the Low Volt power supply board from the working printer and put it into the bad one and it still gives me the same code...
    anyone knows where I should look next.
  • prntrfxr
    • 1622
    It might be good to get yourself this manual as you will probably see this printer again. Here's what the service manual says about this error:
    50.X FUSER ERROR
    For help press
    A fuser error has occurred. The values for X
    are listed below.
    ● 50.1: Low fuser temperature
    ● 50.2: Fuser warm-up service
    ● 50.3: High fuser temperature
    ● 50.4: Faulty fuser
    ● 50.5: Inconsistent fuser (verify voltage
    model)
    ● 50.6: Open fuser
    ● 50.7: Pressure release mechanism
    failure
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • Jose
      • Nov 2009
      • 9
      The problem was the dc control board. Change out the controller board test ok
