HP Designjet 750c, cutter question.
Customer replaced himself the printhead drivebelt. Since than the cutter doesn't function anymore
The printhead carriage moves too far to the right (I think) causing the cutter to be latched and unlatched at the same time. I understood it should function as follows: The printhead carriage should move to the right just under the blade spring of the cutter to latch in and pick up the cutter to drag it to the left cutting herewith the paper. After cutting, both units are moving back to the very far right thereby unlatching the blade spring of the cutter.
Question: Is the amount of travel to the right, home position of the cutter, determined by the encoding strip and sensor system in the carriage or is there a separate sensor detecting to where and how far the carriage must move to latch and unlatch the cutter respectively?
Hans
Hans
