HP LJ P3005 replacement
  • Ducttape n Glue
    • 195
    Ok, customer bought 5 of the 3005dn printers in Jan of 09. Had them installed in June of 09. May of 10 , 3 of the 5 have bad formatters. Needless to say they are not happy. We did not sell them, their outsourced IT people did and called us when they started to have problems and couldn't figure out what was wrong. The IT company won't honor a warranty because its over a year and I sure as heck am not.
    Bottom line: Customer wants to replace the units with something else and would like to buy it from me. I rarely sell smaller units. Can anybody recommend a reliable replacement compatible unit to these 3005's?
    Thanks for any recommendations.
  • Rob Sandberg
    • 275
    Ducttape n Glue.
    1. First remove the formatter from the printers. Preheat your oven to 350 degrees F, or 180C. remove any plastic that you can from the formatter (simm sockets cannot be removed).
    Bake the formatter for 8 mins. Your customer has nothing to loose and you can be the hero. I fixed my fourth P2015 with this method last week (that is four for four).
    2 If needed goto this site for the next generation of printer.
    HP LaserJet Enterprise P3010 Printer series Small & Medium Business
    Rob S
      • 22996
      This whole series of machines has formatter issues, mainly 49.xxxx codes. Good luck with the board baking. =^..^=
      • prntrfxr
        • 1627
        HP 2420s are a downgrade because they are older machines, but they are nearly identical. You'll have to get one with an optional feeder to get 500 sheet tray cause they come standard with 250-sheet tray.
        • Ducttape n Glue
          • 195
          Thanks for the suggestions.
          I have heard of this oven process/hot air rework for the old 615n nic s and some have had success with the 3005 formatters using this and similar hot methods.
          Thing is, customer is done with these units.
          Have the 3010 units proven to be more reliable?
          I'll have to see what reviews are.
          • Rob Sandberg
            • 275
            To new for reviews. Prntrfxr has a good idea.
            Rob S
