HP 3600dn
  • bizhub1
    • Sep 2008
    • 230
    HP 3600dn
    I have a 3600 that is leaving black on the bottom of most pages. I checked the cartridge contacts, also ran disable cartridge mode and switched the black and magenta and all the pages came out with magenta so it is in the black port. I attached some samples, any ideas would be appreciated.
    • 23010
    Since the image defect is a negative of the previous ~9" of image, I'm thinking high voltage. Does the transfer belt stay clean?
    • bizhub1
      • Sep 2008
      • 230
      No, it keeps building up on the belt and starts showing up on the back of the prints
        • 23010
        It could also be a black transfer problem. Cost-wise, I'd start with the transfer belt unit, followed by HVPS. =^..^=
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
          Or if you have something that I don't have, I'm always looking to trade.
          Paul@justmanuals.com
          • prntrfxr
            • 1622
            I would check to see if you have a broken cartridge lock for the cartridge. If the cartridge is not locked in place, it won't make good connection to the contacts. That may or may not be your problem, but since it is a weakness of the machine I'd look there first.
            Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
            • prntrfxr
              • 1622
              I would check to see if you have a broken cartridge lock for the cartridge. If the cartridge is not locked in place, it won't make good connection to the contacts. That may or may not be your problem, but since it is a weakness of the machine I'd look there first. If you replace 1, you should replace all 4.
