HP DesignJet 4500ps Network Problem
  • smrtamang
    • 10
    [Misc] HP DesignJet 4500ps Network Problem
    Hi Frens,
    I have HP DesignJet 4500ps Plotter machine and i faced a unexpected problem. It was working properly before but now after i changed IP address my plotter machine is not receiving any data. May be any mistake or what i don't know. It would be greatness of you if you give the solution on that.
  • nmfaxman
    • 1702
    Change the IP in the print driver port.
    RTFM
    • suckis
      • Dec 2006
      • 165
      Read here.
      It is in Greek but I believe it will help you because there are images too.
      ! RTFM !
      My site: http://www.e-club.gr/
        • 23009
        Like the nmfaxman says,
        You need to have the driver pointing to the same IP address that the plotter is at. Go to Printers, Properties, Ports, Add a Port, enter the new IP address, Apply, OK. Depending on your operating system you may need to look a little harder for the printers folder.
