HP LJ 1300 creases
  • kazu
    [Misc] HP LJ 1300 creases
    I changed the fuser but still the problem persists, also did halftest,Made sure print media is loaded correctly and that the guides fit properly against the media stack...
    • 23006
    Did you try some fresh paper? =^..^=
    • prntrfxr
      • 1622
      Fresh paper is important, but make sure that the fuser is seated properly. I don't remember for the 1300, but 1320 & P2015 have holes that accept pins from the paper guide. If the fuser is installed on top of the paper guide or the entrance guide of the fuser gets pushed out of position during installation, you can have wrinkling issues. Also, you can open the back door to allow paper to bypass the delivery asm to rule that out too. A bad cartridge can sometimes cause wrinkling. Hope all this helps you.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • kazu
        Thanks guys let me try and will let you know
