HP 5M Idler gear
  • cucuklotz
    • Mar 2007
    • 611
    HP 5M Idler gear
    Hi, I replaced fuser but didnt see idler gear also broke(i thought I looked).I couldnt find in Manual how to replace it. is there an easy way to replace idler gear that drives fuser,
    thanks Andy
  • prntrfxr
    • 1627
    You have to remove the formatter board, the motor, then there are 2 screws for the gear drive. You need to buy a coupler gear and will need retaining ring pliers to remove the ring that holds the pin that goes through the gear. Not too difficult.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • cucuklotz
      • Mar 2007
      • 611
      HP 5/IDLER GEAR
      HI,
      Thanks as always for the many times you have helped me Prntrfxr.
      ANDY
      • cucuklotz
        • Mar 2007
        • 611
        PS PRNTRFXR<
        Your message box is full and cannot accept private messages so I thank you again for your added help.Enjoy rest of summer.
        ANDY
        • prntrfxr
          • 1627
          thanks...problem with message box fixed. Sorry 'bout that.
