HP 4050T 55.A Error
  • deep
    • Jun 2008
    • 208
    HP 4050T 55.A Error
    I'm getting a 55.A error on this printer. It just keep on running when power on.
    Press GO button do nothing. Any ideas? Would it be the Formatter PCA or Engine Controller the most possible fix?
    Thank in advance.
    Kenny
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
      • 23008
      My manual does not offer a definition of the ".A" portion of the code, but for "55.xx" I have:
      Internal Communications Error.
      First firmware DIMM, then Formatter, then Engine PWB.
      Personally I've not seen this one before. =^..^=
      • deep
        • Jun 2008
        • 208
        Thanks for your response blackcat. There is also no 55.A error code in my manual too, only has code 55 which is a Internal Communications Error occurs inside the machine.
        Also this is the first time I come across with this strange code.
        Kenny
        • JustManuals
          • Jan 2006
          • 9838
          Why don't you search for this error on the HP tech forums. I'm sure it's been addressed there.
          HtH
          • deep
            • Jun 2008
            • 208
            Paul, thanks you very much for your precious advise.
            I just curious why HP don't list all the codes in the manual and the instructions ain't clear.
            I think most the techs have to "search in the dark" to find out the solution when there are new problems arose.
            Kenny
            • JustManuals
              • Jan 2006
              • 9838
              HP isn't the company today as it was when it was building it's reputation. Now it's just another cheap Chinese junk company. The 4000 series was a great printer though. I've worked on a ton of them back in the day I was in the field.
              Paul
              • deep
                • Jun 2008
                • 208
                You're right, this printer has been working flawlessly over 8 yrs.
                A good machine indeed.
                Kenny
