HP 4600 52.2 code
  • rocky_biskit
    • Jun 2009
    • 76
    [Error Code] HP 4600 52.2 code
    Have a customer with an hp4600 (color) 52.2 error message. Need to know possible causes/and or fix and reset procedure if any. Not sure if this is laser related, if so will cleaning of the laser assy. solve the problem?
    Thanks in advance to all ... you guys (and girls) have always come through for me!
  • mo0651
    • 1054
    Scanner start up error. Reseat connectors. could be scanner or prcb
    • MBT
      • Aug 2010
      • 51
      The 4600 has 4 lasers. You should have gotten a 52.2x error. x should be 0 for black, 1 for cyan, 2 for magenta, and 3 for yellow.
      I'd try doing what mo0651 says first and see if that fixes it. If not it's possible the motor has seized in one of the lasers. You can try lubricating it, but when it spins up the lubricant can get on the lenses. Your best bet is to replace the failed laser.
      Service manual shows how to do so, it's not too bad. If you don't have the manual you can probably find it by googling or buying it from justmanuals who advertises here.
      • JustManuals
        • Jan 2006
        • 9818
        This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
        Paul@justmanuals.com
        • fixthecopier
          ALIEN OVERLORD
          • 4711
          There is a certain way you want to change those lasers, you should read a manual
          • prntrfxr
            • 1618
            The laser scanners are one of the weaknesses of this machine. Listen to fixthecopier. If you replace the scanners without having the instructions and do it wrong you can permanently damage the machine (frame needs a support or the frame gets bent and the lasers will be out of alignment). Get a service manual if you do not have one.
            Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
