LJ 2600n
  • slybot
    • Sep 2010
    • 165
    [CQ] LJ 2600n
    hi all. i have the above m/c here that the customer was complaining about CQ issues. removed and cleaned the dust out of the laser which has made everything more vibrant but now i have no magenta on the demo pages. engine test is fine with all colors. has only happened since i stripped it apart. have gone over it twice to double check everything and still no go. any ideas???
  • slybot
    • Sep 2010
    • 165
    forget about this. it decided to fix itself. thank god for that!
    • JustManuals
      • Jan 2006
      • 9838
      No matter which color laserjet it is, HP seems to always have trouble with the Magenta cartridges. Weird.
      • Hank
        • Aug 2009
        • 25
        By design, magenta is at the bottom of the pile of cartridges which forces mirrors in the laser to look up and collect all the dust possible floating around the inside of the machine. The surprise comes during disassembling of the laser unit, there are no dust seals under the lid to protect the precious scanner.
        Hank
        • JustManuals
          • Jan 2006
          • 9838
          Couldn't think of anything on your own to say? Or did you just post to show your link?
          • Hank
            • Aug 2009
            • 25
            ugh.What link?
            • JustManuals
              • Jan 2006
              • 9838
              Not you.
              • prntrfxr
                • 1627
                Someone after manuals, but before Hank copied manuals comment. I gave him a bad rep, but it seems he or someone removed the post. That's good.
                Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
                • slybot
                  • Sep 2010
                  • 165
                  pieces of snot these things are. think that will be the last one i will work on. will refuse to touch them next time (if i can get away with it)
                  thanks for taking an interest though everybody
                  • prntrfxr
                    • 1627
                    Faded print, especially magenta, is 90% dirty optics, but you have to remove the scanner and hold it up to the light to clean it really good. No parts required but it does take time. If you get in a hurry you may forget to connect something good or forget to use ESD procedures and then you have a bigger problem. I've only had to replace the power supply and the fuser other than clean the optics. The printer is not worth any other repair.
