HP LJ 8150/8100
  • otuvak
    • Aug 2010
    • 102
    HP LJ 8150/8100
    8150 EXAMP.pdfHere is an example of what we are seeing! Just want to know if anyone else has seen this and what they did to fix it! Tried replacing fuser 3 different times. Did half test and is not from toner cartridge. Also tried just replacing press roller and had no effect.
    • 23008
    My guess? That's the laser main scan direction. My guess is that the laser diode is failing, but it could be some other component in the laser unit. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest collection of manuals | Instant Downloads - Just Manuals | The Internet's largest collection of manuals | Instant Downloads
      Paul@justmanuals.com
      • prntrfxr
        • 1622
        I think it may be the transfer roller as it is a repeating pattern and it is small. If it was laser scanner, on this machine (prints landscape), it would be from leading edge to trailing edge. Clean the contacts really good too and make sure that you vacuum/wipe up any dumped toner.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • Rick Martinez
          • Sep 2009
          • 77
          I have to agree with prntrfxr, the transfer roller and contacts. I seen that before, replacing the trans roller and cleaning the cpntacts worked for me.
          • otuvak
            • Aug 2010
            • 102
            I have tried different transfer roller and scanner. Same exact results of lines in the exact same spots! When I do the half test the lines are not there until after fuser. We are not getting the same thing on an 8100. Thinking that the toner is to rich or thick. trying different toner on monday to test theory. Also changed setting on plain paper to high 1 and high 2 didnt make a diference. Adjusted toner density that was at 3 to each setting. Was there any firmware that bumped up fuser temps...etc. Thanks for reading and the ideas everyone.
            • prntrfxr
              • 1622
              Where are you getting your fusers? Also, it may be the LVPS as there is a weakness with it on this machine. But it could also be a DC controller issue as Thermistor voltages are regulated by it.
              • Rick Martinez
                • Sep 2009
                • 77
                Have you check the pressure on the fuser rollers?
                • otuvak
                  • Aug 2010
                  • 102
                  Turned out being the toner!!!!!!!!!! Toner much be too dense and would not fuse it all to paper!!!!!!! Put HP cartridge in and problem dissappeared..........LMI! Thank you everyone! I did try two other LMI's and didnt show up in the half test>>>>>>
                    • 23008
                    Are these compatible cartridges or OEM? Either way, very strange. =^..^=
                    • otuvak
                      • Aug 2010
                      • 102
                      compatibles
                        • 23008
                        I'd try an OEM cartridge first, before spending a lot of time trying to fix anything. =^..^=
                        • CanonHPTech
                          • Apr 2007
                          • 235
                          Just remember.... that everyone and their mom's makes HP toner cartridges since they are so popular and that's where the money is. Only a small percentage of companies make good ones and only a portion of the one's they make work 100% or last to their rated life. When it comes to HP's, check the toner first. I have made this mistake before and I lived to regret it.
                          The glass maybe half full, but less is more...
                          Printer + Fax + Copier = Jack Of Many Trades,
                          but Master Of None
                          Color Copier = Not A Color Printer
                          InkJet MFP = Not A Fax Machine
                          B/W Copier = Not A Press
                          Finisher = Deal Closer (salesman, not accessory)
                          Copier Tech = Admin's Stress Ball (Scapegoat)
