This machine has approx 120000 pages on it. It went through its original fuser and a remanned in about 10-11 months and had 11000 pages on the reman fuser. Is there something known on these machines for chewing up fusers or an update?
LJ 4200dtns
Could you be talking about gear damage? Take a look at the swing plate (fuser coupler gears in the side frame). =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
If the white gear behind the black one in the swing plate is also worn, you need to replace the whole swing plate, not just the kit.Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".Comment
If you replace the film in the fuser, make sure while you're in there to inspect the pressure bushings. I believe the bushings causes vibration and that that is what causes the swing plates to fail prematurely.Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".Comment
