Replacement Foam for feed solenoids
+ More Options
Posts
  • Wild Bill
    • Jul 2005
    • 774
    Anyone know where to get replacement foam for hp laserjet feed solenoids. I have been buying the solenoids but it seems a waste of time and money if I could just plop on a strip of foam. Thanks for any info!
    Izzy
  • Rob Sandberg
    • Jul 2008
    • 275
    Wild bill
    Go here for more info on this problem.
    This thread is for HP LJ 4100's but applies to your problem
    HP Laserjet 4100 Error (13.1) - fixyourownprinter.com
    You can use many types of material to dampen the noise, electrical tape, foam strip, felt.
    Just remember not to defeat the action of the solenoid.
    Rob S
      • 22997
      I've been using black tape for quite a long time. =^..^=
      • CraigW
        • Dec 2010
        • 417
        Black tape for me as well, 2-3 layers.
        I have some felt circles... but some solenoids don't have enough clearance for them & the felt will bind it's operation.
          • 22997
          Today I tried something a little different. I used the hook side of adhesive Velcro. I still damps the noise, and there isn't much risk of the adhesive bleeding through. I think either side of the Velcro would work fine. =^..^=
          • Iowatech
            Not a service manager
            • 3930
            Re: Replacement Foam for feed solenoids
            Wow, am I ever late to this, but I think this is exactly what I needed, so thanks!
            • prntrfxr
              • 1627
              I use Canon separation pads (FC5-4368) that I cut down with a razor blade to fit. Almost all of the solenoids I fix are too small for felt. These just dampen the sound.
              Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
                • 22997
                Another thing that works is rubber. I've punched some 13mm disks of rubber from a bicycle inner tube. A small spot of cyanoacetate secures the disk where you need it. =^..^=
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  back when i used to work on HP laser printers 10 years ago, i used to have a supply of 3mm adhesive backed foam that i used for this specific purpose.
                  I was working on the canon SX engine HP Laserjet II and from memory it was a couple registration solenoids that caused interesting paper jams when the factory foam on the tops of the solenoids disintegrated into a sticky mess. Good to see absolutely nothing has changed since then
                  BTW, it was essential to use something as simply removing the factory foam and and cleaning them didnt work, metal on metal resulted in some kind of residual magnetism and the solenoids stayed activated for way too long..
                    • 22997
                    Yeah, I discover that. I had to replace a couple before I learned. =^..^=
