At first there was a line and smudging on one side with white streaking in middle. The toner was low and the drum looked fatigued so I changed the imaging unit. Some marks went away but otherwise almost the same. I changed fuser unit and got rid of smudging and line but the white streaking is still there. Also changed transfer roller.
The toner is not HP but that is because it is the Micro toner for printing checks and HP does not provide it but refers you to a 3rd party called Troy. It was a Troy cartridge in machine. I replace it with a competitor's Micro cartridge and streaks remained. Troy charges $450 for a cartridge.
The customer is not complaining about the white streaks as they are less obvious now when printing checks which customer uses this machine exclusively for. On regular bond paper the streaking is more obvious as I used it for test prints. Any information is appreciate. I am just concerned that it may get worse and I'd like to eliminate streaks. Frank/ActionPhotocopy
