hp clj 9500
  • CT Copier Repair
    • Mar 2010
    • 304
    hp clj 9500
    customer moved machine
    someone else troublsot it said they needed a power wupply
    no display no fans
    replaced power supply that they received now it powers up error 50.6
    fuser?
    i checked all connections etc could not find anything
    funny thing
    when i removed the fuser and cheated the left door interlock it went ready for a second then into error 50.6 never saw that before
    Brian
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
      • 23008
      The 50.6 code is a common fault with power supplies. Perhaps it was a used or almost repaired power supply? =^..^=
      • CT Copier Repair
        • Mar 2010
        • 304
        well it was a "pulled from new machine that was never powered on"
        replaced the fuser as it did have a problem ( bad center thermister) but still there
        so i took the old power supply and am going to try and fix it this weekend
        if not then a known working ps and then a dc controller but I haven't seen that many dc controllers go bad on the high end hp's
        any help would be appreciated
        thanks
        Brian
        • prntrfxr
          • 1622
          Make sure this printer is plugged directly into a known good outlet. It has a sizable power draw and will not work well in most surge protectors. Some work environments don't have consistent power from outlets and that can be a problem with these machines. The 9000 series printers have had problems with dc controllers. I don't remember anyone saying that about the 9500, though.
          Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
