What would be the most probable cause of this printer NOT firing up the fuser unit? These fuser units work in other printers of the same model when swapped.
HP(CLJ)8500DN--Fusing unit error,even when replaced with a new one
Formatter??? for the fuser? I maybe wrong, but I don't think so. A bad LVPS will cause a 50 error if the fuser is good. If the fuser is not heating up, that's where I'd go next.
RH3-2185-000CN 110V Power supply
RH3-2187-000CN 220V Power supply
They are not cheap. You might consider a refurbished one or get your client to update their machine.Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".Comment
Ha, Ha Ha, I can not picture you as being "The Man" , prntrfxr.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
I am the woMAN.... yay! LOL. I have learned not to take it personally.Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".Comment
