Ok, so just recently we had one of these devices pop up a install MK message. When this happened the users were coming in the next day with a 49.4c06 error message. We installed a new MK and upgraded the firmware.
Everything was fine for about a month now they are getting 49.4c027. This error happens in the middle of the night when I check the event log (various times). They are on the most current firmware version 20110220 09.230.9. Had a thought that maybe the device was going into sleep mode than some one was sending a fax in middle of night that was triggering it. So had user put device in sleep mode and I sent them a fax but it worked ok. We performed a DISK INIT and error still occured during the night.
At this point we put in a new formatter with updated firmware, new HDD, new fax module, memory, etc. Still getting the error message at various times of the night. After a reboot in the morning it works fine till next morning when error happens in middle of night.
At this point thinking a NVRAM/cold reset on the device, but not sure if this will resolve it as it went away for a month after MK message went away with install of MK. Any other suggestions??
Also have another one of these devices at another client, it also came up for a MK. At the time the message appeared they too started getting 49.4c06 errors. Theirs happened a few times a day though. I installed a new MK and did a firmware upgrade on this device 1 week ago and the errors stopped at this point. Kind of worried that it was showing the same problem as the other device really hoping it does not turn into the 49.4c27 in a few weeks like the other one.
