HP CP2025
  • otuvak
    • Aug 2010
    • 102
    HP CP2025
    2025.pdfHaving the following issue with this machine. Seen other post about this. I am attaching(hopefully) some examples to look at. Has current firmware and new OEM toners. Thanks for looking2025.pdf
    • 23002
    Re: HP CP2025
    To me it looks like a damaged transfer belt. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      Re: HP CP2025
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Paul@justmanuals.com
      • Wild Bill
        • Jul 2005
        • 774
        Re: HP CP2025
        I would run Print quality diagnostics page, that way you could pin point a toner cartridge if one is bad. I know you said they were all OEM but one may be bad anyway. Did you say you replaced them? Thats where I would start, then calibrate it 2 / 3 times. Try cleaning / Check the scanner slit glass ( dont know much about these but we have some of them in the field and I would like to hear what you come up with). good luck
        Izzy
        • Caldo
          • 69
          Re: HP CP2025
          I agree with blackcat, the transfer belt might be faulty. Otherwise have the cartridges checked one by one, as there maybe a faulty cartridge which might need replacement. I sometimes come across this situation and after several attempts on cleaning the transfer belt, rollers, slit glass, etc it works again but if there is a faulty cartridge though it is OEM replacement will only solve the problem.
          Let me know of your progress.
          • Lasersupplies
            • Jul 2011
            • 221
            Re: HP CP2025
            This could be a scanner problem. Send a print job to the printer an ordinary text document. Check to see if the text prints normally . The bands across a page with a faulty cartridge will appear four time down the page. With a scanner problem the band will be intermitent appearing two, three and four time. My guess would be that the 3700 has a defective scanner.
