HP LJ 5N follow-up
  • tcypy1961
    • 773
    HP LJ 5N follow-up
    I looked on precision rollers web site and saw a gear that looks like the gear on the inside that the fuser meshes with. The gear is worn. I noticed a gear on the fuse that looks like the gear on the inside which appears to be the gear Precision Roller is showing. Does anyone know if they are the same gears???
    Thanks!!!
  • prntrfxr
    • 1622
    Re: HP LJ 5N follow-up
    RF5-0350 is the coupler gear that touches the fuser gear.
    RS5-0237 is the gear that fits inside the coupler.
    You have to remove the cartridge, fuser, formatter, motor, and then 2 screws secure the drive assembly. TSA sells them too or you could use Parts now, Precision Roller, or any other vendor.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
