50.7 FUSER ERROR
  • myli
    [Error Code] 50.7 FUSER ERROR
    Hello
    There CP4525 device. Fuser and fuser drive assy . Despite the change of error 50.7 fuser error. Cables were checked. Reason you think.
    was the so-called service manual. But the problem being solved. Do you Have a different solution?
  • prntrfxr
    • 1622
    Re: 50.7 FUSER ERROR
    Service manual says:
    1.) Reconnect the fuser-pressure releasesensor intermediate connector J60, and
    connector J128 on the DC controller
    PCA
    2.) Run the sensor test in the sensor
    monitor mode to verify that the fuser
    pressure-release sensor is functioning
    properly. If it is not, replace the fuser
    pressure-release sensor.
    3.) Check the fuser pressure-release
    sensor flag. If it is damaged, replace the
    fuser.
    4.) Run the fuser pressure-release drive
    test in actuator drive mode to verify that
    the fuser motor is functioning properly.
    If it is not, replace the fuser motor. See
    Fuser motor on page 200.
    5.) If the message persists, replace the
    fuser. See Fuser on page 85.
    I assume you have tried every one of these steps. What were the results of the sensor test and the fuser pressure-release drive test? Did you replace the pressure release sensor? Did you replace the fuser motor? When you have tried everything else the DC controller would probably be the next step. Please reply with the resolution to the problem when you find the fix.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
