HP 4350
  • otuvak
    • Aug 2010
    • 102
    HP 4350
    Have an HP 4350 with a broken clip that holds the transfer roller clip on the right side of machine as you are looking at the machine from the front. This looks like a pain in the ass to fix. Any one had to replace this? Machine works fine but transfer roller will come out easily.
    • 22997
    Re: HP 4350
    If I'm envisioning this correctly, there's a spring loaded bushing in the plastic center frame. If it's the bushing that's broken, easy fix. If it's the frame, well your screwed. =^..^=
    • otuvak
      • Aug 2010
      • 102
      Re: HP 4350
      You are correct in you assumption! Thanks for the post. I wont waste my time and effort looking for a solution. Thanks again.
      • prntrfxr
        • 1627
        Re: HP 4350
        You would have to replace the transfer frame. I think I have one. It is a bear to change (requires removal of metal side frame).
