HP 5000/JETDIRECT
  • cucuklotz
    • Mar 2007
    • 611
    HP 5000/JETDIRECT
    HI,
    Customer getting code more frequently referring to Jet dierect.
    I ordered one to replace .I know nothing about printers other than I can handle the basic problems. Is there anything Ill need to do when I swap The jetdirect out( besides praying).
    THANKS ANDY
  • Eric1968
    • 2458
    Re: HP 5000/JETDIRECT
    Switch off the machine.
    • cucuklotz
      • Mar 2007
      • 611
      HI,
      THANK YOU,
      I mean are there any settings that are going to need to be changed or is it just Plug and play.
      Andy
      • prntrfxr
        • 1622
        You may need to set IP address. I have a Tech Tip that can help walk you through it.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • cucuklotz
          • Mar 2007
          • 611
          HI,
          THANK YOU for tip sheet.I think even I can follow that.AS always your generous spirit of giving has once again made the challenges a little easier.
          ANDY
          • MR Bill
            • 532
            There are a # of different network cards.
            Hope you didn't get the 615N. It will fail again in no time. Use the 620N or newer.
            And yes you need to reprogram the IP address, Sub-net and gateway.
            Looks like you have that info already. If not Liberty or Parts Now can get it to you.
            Best to you.
            • cucuklotz
              • Mar 2007
              • 611
              Hi,
              I replaced the jetdirect with the same model #(610)It did the trick.When I reinstalled old one as a test the machine didnt even print a jetdiect page when I printed configuration. It was completely dead.
              THANKS for All the help.(especially TOM.even though he didnt help with this one) ANDY
                • 23009
                I replace the Jetdirect 615 with Jetdirect 610 as a rule. The 610 is more reliable, and there are only one or two models that must have the Jetdirect 615. Congratulations. =^..^=
