HP LaserJet 4250dtn Printer
  • brunot
    • May 2012
    • 148
    [Jamming] HP LaserJet 4250dtn Printer
    intermittent jamming in fusing exit section
  • Eric1968
    • 2458
    Re: HP LaserJet 4250dtn Printer
    Yes, and what did you do already?
    • mo0651
      • 1054
      Cool!!!!!! They can do that. Any more hints before we throw a really large list of things. HMMMM. Do you know what jam code?
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Wow that is a lot of info to work with. Could there be a mouse or small bird living in the fuser?
        • Wild Bill
          • Jul 2005
          • 774
          It's 13.something
          Izzy
          • chris17_rose29
            Try to open at the back of printer maybe the fuser film has been damage.
            • JustManuals
              • Jan 2006
              • 9838
              Isn't this the HP printer with the swing plate assembly problem? Is there noise with the jamming?
              Paul@justmanuals.com
                • 23010
                It's certainly one of the possibilities. Usually accompanied by piles of gray dust and squealing noise or gear growling noise. =^..^=
                • Eric1968
                  • 2458
                  Yes, it is! If you're lucky you can hear the machine printing a few hundred meters away...
                  • Chameleon
                    • Nov 2011
                    • 200
                    We have been having a rash of fuser jams on many HP's I work on because of the crappy aftermarket fusers we have been getting. I think the grease on the inside of the film dries out or maybe there is too much. I've had 3 this month where they don't jam for me but the event log will be full of 13.05 jams. I'd rather not bash vendors here but try an OEM fuser. GL
                    The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
