Re: HP Laserjet 3005
Check the solenoids and linkages that control the duplex gates, check to see if there are little rubber sound deadening pads that are going bad and binding the works. I had that problem a while back - intermittent jams, mostly on duplex but sometimes not, and not ever enough that I could do a stop test. It drove me nuts! Then I read about the pads going bad and leaking adhesive in a previous post in this forum, and after scraping those pads off and cleaning the offending adhesive from the parts, success! And it really wasn't noticeably noisier afterward (but it was in a livestock feed store, so maybe no one noticed it).
Hope that helps.
HP Laserjet 3005
Its the top paper tray, I called the customer this morning and they said that it was jam free. Had them load tyhe paper per ream label and strengthened the paper drawer lift springs. Maby that fixed it...Leave a comment:
Tray 1 is the MP or bypass tray. Tray 2 which the paper cassette. Which one is jamming?
Sounds like the duplexing pendulum is getting stuck; Lube Pendulum assembly / Swivel duplex;l Is it throwing 13.05 / 13.20 ErrorsLeave a comment:
No WD40. Never. =^..^=Leave a comment:
Is the tray damaged at all, how are the friction pads, and have you put some wd40 on the roller bushings at each end.Leave a comment:
Hey Doug; This Parts & Service Manual can now be purchased for $12.77 and downloaded immediately after payment from
Paul@justmanuals.com
HP Laserjet 3005
Intermittent jams on large jobs from tray 1. Can't seem to observe problem but copies that have jammed show significant skew . First seemed to be happening on 2 sided only, now seems to be happening on the first side of 2 sided jobs. Adjusted tension on exit rollers and strengthened paper tray springs. Waiting to see if that fixed fixed it. Rollers are fine, the only thing I can think of is maby the tray 1 feed clutch...Tags: None
