HP LaserJet 4515 Paper Feed Z Shaft
  • CanonHPTech
    • Apr 2007
    • 235
    So, clip came off shaft that gear that link feed and p/u roller and gear, spring, etc. all lost. So I return with Paper Feed Shaft Z Assy. thinking I can just swap what I need from it... however I guess HP updated the assy. with a narrower shaft so the old style shaft wont take the new clip. Long story short I ended up having to dig into machine from right and swap whole assy. Any thoughts or shortcuts? Thanks.
    The glass maybe half full, but less is more...
    Printer + Fax + Copier = Jack Of Many Trades,
    but Master Of None
    Color Copier = Not A Color Printer
    InkJet MFP = Not A Fax Machine
    B/W Copier = Not A Press
    Finisher = Deal Closer (salesman, not accessory)
    Copier Tech = Admin's Stress Ball (Scapegoat)
  • Wild Bill
    • Jul 2005
    • 774
    Re: HP LaserJet 4515 Paper Feed Z Shaft
    Not sure but isnt the 4250 the same? If you have any 4200/4250's around ; just a thought.
    Izzy
    • CanonHPTech
      • Apr 2007
      • 235
      Thanks for reply. It does look like LJ 4250/4350 has similar style pick up shaft but can not find a part number for clip that holds the works in place. Also, not sure how HP updated the Z-Shaft assembly with out changing the ending of part number. Hopefully I won't encounter this again.
      but Master Of None
        • 23006
        I've seen broken plastic feed shafts on LJ2100, LJ4L, LJ5P, and CLJ CP3505N. Each one is a little different. If you don't mind spending two hours making a $2.00 part, I've made a few feed shafts from scratch (steel rod). They're better than any OEM part in every way. =^..^=
