HP 4100N prints out blank sheet then a 13.1 jam code
  • acsolutions
    • Jun 2010
    • 519
    Hello,
    I checked all the paper feed sensors and blew out sensors same problem tried pressing button on side of machine for engine check showing jam after a few sheets. I'm wondering if there is a laser start issue possibly a sensor. any suggestions
  • Wild Bill
    • Jul 2005
    • 774
    Re: HP 4100N prints out blank sheet then a 13.1 jam code
    Paper feed solenoid; Clean off foam off or replace feed assembly
    Izzy
      • 23009
      Replace foam with similar thickness pad. The actuator will magnetize if it makes direct contact, metal on metal. =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • MR Bill
          • 532
          There is a real good articale in the Service Edge from Liberty Parts. It has just about all problems and solutions for paper jams on this model. HP 4000 - HP 4050 - HP 4100
          articale from about the first quarter of this year.
          www.lbrty.com
          • acsolutions
            • Jun 2010
            • 519
            Cool, if the solenoid is stuck full time, then when you turn on the machine it should feed a sheet of paper. what I mean is that as the engine rotates so should the paper feed roller, all the time! Thanks
            • yurisan
              • Dec 2007
              • 118
              Most common manifestation of this problem is this foam pad on the paper pickup solenoid getting gummy and sticking long enough to allow a second sheet in and misfeeding (misfed sheet WILL be blank). Does not typically stay actuated very long past its normal duty cycle. You can simply remove this foam, which will result in a clicking sound when feeding paper, or as suggested add a patch of mylar/vinyl label to replace the foam. "When in Rome, visit the Pope." - i.e. if you have a machine down to this level, it makes sense to check this solenoid as preventative maintenance.
              • hekotez
                • Jan 2007
                • 91
                What i do is remove the foam, then apply a small piece of heat shrinking tube. wont have problems ever again.
                • kannuki2
                  • Feb 2012
                  • 398
                  acsolution, I just had this problem last week and hope this is the same for you. I found that the spring on the cover access switch wasn't locking in and sometimes it doesn't activate the switch when the machine vibrates. I got the same jam code too.
                  I did the hard way. I replace both solenoid and drive gear assembly, until the spring fall out of the interlock switch, I taped the end of the spring back in position and it works like a champ.
                  check
                  WC4-5139 Switch Top cover interlock access switch
                  • acsolutions
                    • Jun 2010
                    • 519
                    check
                    Yeah, it was the foam pad! Thanks for replying
