Hp 4345 skew from tray 3
  • mrfuser
    • 1622
    Tray 1 & 2 are fine, skews only from tray three. Swapped out new feed rollers and cleaned path. No good still.
    any ideas?
    kelly
  • prntrfxr
    • 1622
    Re: Hp 4345 skew from tray 3
    Torque limiter (clutch in the tray) issue?
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • ucinn
      • Jun 2009
      • 383
      any ideas?
      kelly
      Bent tray perhaps? Did you try swapping the trays to see if the problem moved with the tray?
      • CRam007
        Do you have any specific error code on the control panel? as Ucinn said many times is a tray issue, and when you said just with the 3 tray means tray 2 and 1 works normal with no problems printing a heavy amount of prints?
        let us know more details
        Regards
        • mrfuser
          • 1622
          Yes only tray 3 skews , no error as it spits it out fine just skewed image
          • CRam007
            Ok, what happens when you change the tray position? (tray 2-3) and also i would recommend you check if the paper came in the right way from this tray also make sure the guides paper on the tray aren't to tight and properly seat.
            • mrfuser
              • 1622
              It is not the tray I switched first. Did all else you mentioned.
              This ain't my first rodeo on these guys.
              If it were easy we would all be doing it! Lol
              • Iowatech
                Not a service manager
                • 3930
                This might not help a lot (and if so, sorry about that), still, have you checked out the operation of the paper feed solenoids for drawer 3? Specifically whether they get hung up on the noise reducing rubber pads?
                • CRam007
                  Ok Genius,
                  then you should discard with another entire good know tray 3 seems as prntrfxr said a tray's clutch issue.
