HP p3005 Settings Help (Legal/letter)
  • kkita
    Hi All,
    Hopefully you guys can help me out. Let me know if you need any more information. I did a quick search on the forums and google, but couldn’t find anyone with this problem. A user has a P3005 with the PCL5 driver, on Windows XP. I can't print to a different type of paper (Legal or Letter) without changing the settings on the machine itself.
    On the Machine I currently have
    Tray 1: Letter
    Tray 2: Letter
    Tray 3: Legal
    In the printer preferences there’s no mention of tray 3 when printing.
    Also It doesn’t let me print to legal at all – regardless of preferences set on the computer. If I change the setting on the printer itself: tray 2 to Legal it will pull from tray 3(legal paper), but when I do that it doesn’t let me print to letter when I choose any settings on the computer.
    Has anyone seen this, or may know what I’m doing wrong here. Let me know if you need any more information
    Thanks,
    Kevin
    Edit: Tried restarting and re-installing the drivers multiple times.
    • 23010
    Re: HP p3005 Settings Help (Legal/letter)
    I see what paper you have loaded ... but what paper sizes and media types are programmed in the Paper Handling part of the menu? I suspect that tray #3 is programmed to some size other than legal/plain. On the machine I saw the other day it was "B5"/plain (a European paper size). I can be pretty sure that this printer will not ever be called on to print onto B5 sized paper. =^..^=
    • wseyller
      • Sep 2012
      • 1129
      If the driver doesn't recognize some options then maybe the wrong driver or maybe try a different driver either way to see if you get a different result.
      Sent from my Galaxy Nexus using Tapatalk 2
      • sandmanmac
        • 3983
        You've made no mention that you have in fact 'installed' tray 3 in the printer properties dialog box on your PC:
        Control panel/ Printers/(right click) HP P3005/ Properties / device settings / installable options/ tray 3 (installed)
        • kkita
          Hey all,
          I'll try the 3 options, hopefully it works! I'll let you know the results!
          Thanks,
          Kevin
