Event code 30.01.41 on the LJ M4555
  • Iowatech
    Not a service manager
    • 3930
    [Error Code] Event code 30.01.41 on the LJ M4555
    This has been kicking me in the sitting muscles for a while recently, just wanted to see if anyone had any suggestions.
    On a lighter note, there is a pretty good chance this is at least partially my fault. I replaced the scanner control board before I found out the read motor in the document feeder was acting badly in component test mode. So I guess it is at least kind of likely that the bad motor did in the new board.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Event code 30.01.41 on the LJ M4555
    Iowa: Send me an email to paul@justmanuals.com and I'll send you a free copy of the Parts & Service manual.
    Regards;
    Paul
    • Iowatech
      • 3930
      Update:
      The manual helped quite a bit (the CPD is the culprit, and it is part of the formatter), but after two formatters it is time to try something different. I'll see if a line voltage monitor will provide some clues.
      As many times as I tell others to check the voltage coming from the wall outlet, it would be ironic if that is the problem here.
      • Iowatech
        • 3930
        OK, the machine has been working long enough, here's what currently looks to be the cure for this error code:
        First, do a partial clear to temporarily get rid of the error code. Then run the scanner tests to see if there is a bad motor in the scanner. In my case, it was the "read" motor in the doc feeder and it was very easy to hear once I thought of testing it. Replace any malfunctioning motors you find, then the formatter. Might want to have the scanner control board handy too, but it is probably not necessary.
        Hope that can help someone avoid the stupid crap I went through for this.
          • 23008
          Thanks for sharing your trials Iowatech. It's sure to help someone here. =^..^=
