Hp Laserjet 1300 orange LED flashing
  • willy brown
    • Aug 2025
    Hi All
    Tell me what this means
    thanks
    • 23010
    My pdf manual won't open.....corrupt.
    Usually the way these work is that there is a cryptic sequence of blinks.
    For example, on 1 second, off two seconds, etc...
    I'll see if I can get a fresh download.
    • sdcparts
      The flashing orange light is a basic attention light. Check the following:
      1. There is a known good toner cartridge installed
      2. There is paper in the tray
      3. The long tab on the top of the inside of the cartridge access door is not broken
      4. Connector J210 on main board is intact, tight and all 3 pins are present
      5. That the drum drive engagement is working properly and the contact is present
      6. The main motor connector is seated tightly
      • BAAKLINIELIAS
        a reason of many is the contact of the mechanist with the drum is good when you close the door
