HP CP2025 meter reading input
  • hillbilly
    • Mar 2011
    • 7
    I have had to replace the formatter on a HP CP2025. Network card on formatter failed. I have inputed the serial number but I cant input the meter readings to their correct number.
    any help would be appreciated
    • 22997
    Re: HP CP2025 meter reading input
    Perhaps these PJL commands will help you.
    First edit the .txt file for the correct serial number and copy count.
    The simplest way to send these PJL commands to the printer is to use the LPR Jar utility.
    • HP:guy
      • Feb 2013
      • 279
      You can't. The only thing you can do is reset the maintenance counts.
      • Wild Bill
        • Jul 2005
        • 774
        Hey Black Cat,
        I have a couple 2200 printers (w/out display) That lost the serial numbers .
        Would this be the same procedure? Thanks
        Izzy
        • hillbilly
          • Mar 2011
          • 7
          thanks blackcat on the text against set pages how should the info be typed I have 2 readings colour and monochrome to input
            • 22997
            Sorry guys, that's all I've got. I've never had a chance to try it before.
            My Printer Job Language manual does not offer any new details on the @PJL SET command. =^..^=
