HP Color LaserJet 4700 jamming 13.12.00
  • m2digital
    • Dec 2013
    • 19
    [Jamming] HP Color LaserJet 4700 jamming 13.12.00
    Hi all.
    I have HP 4700 that is jamming at location 13.12.00 (duplex path, paper late jam).
    Tried new duplex unit and a new fuser unit but to no avail.
    The jamming is intermittent, it could do anything between 20-200 pages before it jams.
    Total print count is around 300k.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Re: HP Color LaserJet 4700 jamming 13.12.00
    Photo cells for the exit are located under the top cover, on the left side. If they are dirty, it could cause a false signal. I have also seen them get "cocked" and rub the exit actuator flag.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • m2digital
        • Dec 2013
        • 19
        Thanks for that. I have cleaned the photointerruptor under the top cover but to no avail.
        The paper feeler moves freely and its actuator flag is not rubbing against the photointerruptor.
          • 23008
          Does it change state then you block the photointerruper? =^..^=
          • Wild Bill
            • Jul 2005
            • 774
            hp clj4700 13.10 duplex Jams.pdf
            I dont know if this helps because you have 13.12 but I had this problem and it also had 13.12 but mainly 13.10
            Izzy
            • m2digital
              • Dec 2013
              • 19
              Originally posted by Wild Bill
              [ATTACH]23944[/ATTACH]
              What I noticed was that the "Bin Full Sensor Flag" in question was slightly bent forward. I straightened it up, and will keep an eye on the jam history as it's very intermittent.
              http://h30499.www3.hp.com/hpeb/attac...sor%20Flag.jpg
