DesignJet 4000ps 79-04 coding out
  • Toner Boy
    • Aug 2007
    • 365
    'generic' firmware error, upgraded to GW_14.1.1.1 (latest), still exists. Problem reared its head after customer replaced black unit 5 printhead and skipped replacing the printhead cleaner unit. Swapped printheads, checked printhead status and cleaner status (all read OK at this time), performed system checks with no errors. Performed printhead recovery, stared at for hours and rebooted many times, cleaned contact pads for printheads. Sub-code info:
    Code: 0xbabeface
    Severity: Error
    Priority: 3000
    Description: STRING_POWER_OFF
    File: MaskManagerAndes.cpp
    Line: 364
    Class: Software
    Subclass: assert
    Error: Assertion
    Define: ASSERT_ERROR
    Descript: Assertion: "maskSize <=hidden_->memMgr_->getSlotSize()"
  • Kiran Otter
    • Dec 2013
    • 1115
    Re: DesignJet 4000ps 79-04 coding out
    Do you still need help with this? I see it's going back a couple months now.
    • niyaskarimba
      • Sep 2014
      • 110
      DearAll,
      We are getting the same issues.Updated the firmware to(GW_14.1.1.1 (latest)),but still the same issue.
      Already try to swap the HDD of other plotter.Still same
      Anybody please help us to resolve this issue.
      Thanks in Advance
      Niyas Karimba
      • Kiran Otter
        • Dec 2013
        • 1115
        When do you get the error?
        If you have another 4000, try swapping the RAM too.
        Kiran
        • Toner Boy
          • Aug 2007
          • 365
          I'm pretty sure we replaced the ink tube assembly and performed the tube priming, then all was good. But it's been a while...memory is a bit hazy on this one. Just be sure you get the priming cartridges too.
