HP LaserJet 1536df MFP
  • tcypy1961
    • 773
    As seen in the picture above, this problem tends to occur only when copying (on glass or fed through feeder), and when scanning a document to a computer. However, this problem does not occur when the customer prints. So could this be a problem with the lamp? Thank you for any help given.
  • theengel
    • Nov 2011
    • 1784
    Re: HP LaserJet 1536df MFP
    Looks like you need a new scanner assembly. They don't sell just the lamp or scanner, that I know of. You have to get that whole top with the glass as an assembly. I think this is the part #: CE538-60118
      • 23010
      Does the lamp come on? My guess is that it's lighting, but dimly. Hp offers only assemblies on these little tabletop jobs. The only way you can change just the lamp/inverter is if you can scavenge it from a junkyard donor. =^..^=
      • Wild Bill
        • Jul 2005
        • 774
        any update on this?
        Izzy
