cannot select more than one print on HP2200 printer
  • doug
    • Dec 2011
    • 198
    Hi guys,
    I got a customer that can select how many prints they want on the computer, but the printer will only print one at a time....any help?
    Thank you
    Doug
    • 23009
    Re: cannot select more than one print on HP2200 printer
    Is the enduser blocked from making changes in the driver ... for example: number of pages grayed out. If yes, IT will need to give it's endusers some rights. =^..^=
    • Iowatech
      Not a service manager
      • 3930
      Originally posted by doug
      Hi guys,
      Thank you
      Doug
      Any chance you could let us know which print driver is on their computer? And maybe the operating system of the computer?
      Still, if they were able to do that before, you might try turning the printer off and unplugging it for a while. The time it takes to retrieve a standard cup of coffee should be long enough to see if that will help.
      (I can't see your machine, so I took a wild guess based on the limited information you provided. Sorry if it was a waste of time.)
      • doug
        • Dec 2011
        • 198
        No problem and thank you for your input.....I do have limited info on this customer as they told me this over the phone.
        I will try your solution.
        Thank you
        Doug
        • sandmanmac
          • 3981
          Thank you
          Doug
          I don't have a reason for you, but ironically I had the exact issue on an old HP4000 recently. Strangely they could print multiple copies from the multi-purpose tray- but not the paper tray
          They were using PCL6. I re-installed it, reset the printer, etc. Finally, I installed the PS driver and it solved the issue
          It's a mystery
          • theengel
            • Nov 2011
            • 1784
            I had this issue on my home computer once. I restarted and everything's fine.
