hp designjet 4000 scanner recovery system software
  • javier4065
    • Feb 2007
    • 251
    I need this sofware for my scanner . it is bad display says load. How can I obtain it? or How can I solve it ? thanks.
  • Iowatech
    Not a service manager
    • 3930
    Re: hp designjet 4000 scanner recovery system software
    Drivers and firmware for your machine should be on HP's website.
    • Kiran Otter
      • Dec 2013
      • 1115
      Assuming you mean the 4200 scanner, you can order the recovery media from HP. I think they charge $5 shipping. You can't download it, unfortunately.
      If you can't get it from HP for some reason, let me know.. I can create ISO images and share them through Dropbox or something.
      You also want to make sure you don't have a bad hard drive in the scanner PC. They fail pretty regularly because of heat. It's a little 2.5" laptop hard drive, so it's easy to get a replacement. Listen for it to spin up when you turn the PC on, and listen for it clicking repeatedly.
      Kiran
      • pgodfrey
        • Jul 2015
        • 14
        Kiran
        My sincere apologies for digging up an old thread, but I've been pulling my hair out trying to locate A N Y T H I N G for my 815mfp (800ps/dj4200). Calls to HP have resulted in "we have no idea what a Designjet 4200 is".
        I would greatly appreciate an image. It's the basic touchscreen PC that shipped with the 4200, running Windows 2000. I'll also send you a private message.
        Thank you in advance!
        Phil
        • Kiran Otter
          • Dec 2013
          • 1115
          Looks like HP doesn't supply those CDs any longer. Only for the 820MFP/4500.
          I sent you a PM, Phil, with some Dropbox links. If anyone else needs these just let me know.
          Kiran
          • copycenteraigio
            • 2
            Kiran
            Hello, im having the exact problem, my scanner that i bought (it was a used one) came without a system recovery disk, i have sent you a PM, i will really appreciate it if you can help me too.
            Thanks!
            • pgodfrey
              • Jul 2015
              • 14
              Thanks!
              If Kiran doesn't reply, I sent you a PM with the .ISO images that he provided me with years ago. Mine is still running strong.
              Best of luck!
              • Kiran Otter
                • Dec 2013
                • 1115
                Thanks pgodfrey. I also sent a PM. Just forgot to mention it here.
                Kiran
                • copycenteraigio
                  • 2
                  Kiran
                  i bought a used hp design jet 4200 scanner including the scanner, the base, test page and the pc unit with the software (windows 2000 profesional and hp software hp design jet). i did not take any other cds or other software. now my toughsceen pc crashed. can i load iso to an other pc unit whith win 2000 and make it work??
                  • Kiran Otter
                    • Dec 2013
                    • 1115
                    Yes, you can restore the image to a blank hard drive on another computer and it should boot. I've even done it with a virtual PC. Whatever PC you use needs to have drivers available for Windows 2000 however, specifically whatever firewire card you use.
                    Kiran
                    • Plotterguy
                      • Mar 2022
                      • 11
                      Kiran
                      Hi Kiran, I have a surplus HP Designjet 815mfp and can't seem to locate anyone with a Recovery CD or just an ISO Image that I could burn to a blank . Would you have any info on where I might find something or someone that has this firmware? Thanks.
                      • pgodfrey
                        • Jul 2015
                        • 14
                        Here are your two ISO discs. They both burn to a Compact Disc, one image per disc. This will allow the restoration of the touch screen PC to factory settings running Windows 2000.
                        Dropbox - HP80_CD1.iso - Simplify your life
                        Dropbox - HP80_CD2.iso - Simplify your life
                        • Plotterguy
                          • Mar 2022
                          • 11
                          Many thanks pgodfrey.
                          • pgodfrey
                            • Jul 2015
                            • 14
                            • Plotterguy
                              • Mar 2022
                              • 11
                              pgodfrey, both images burned to CDs without incident. Thanks again. If you need a new belt for your 800 take a look at LPS computer out in Valley Center CA. They have the best belts including a life time warranty. They're a little pricey at around 50 bucks but they will last long after the print heads dry up!
