hp designjet scanner 4200 is not reconized
  • javier4065
    • Feb 2007
    • 251
    I have a problem with this scanner, the sofware doesnot detect it, maybe someone could help me, thanks in advance.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: hp designjet scanner 4200 is not reconized
    More info....
    O/S
    NIC or USB
    Single PC or server....
    Your attempts to fix it.
    • Kiran Otter
      • Dec 2013
      • 1115
      Yeah, more info would be helpful. Are you using the standard touch-screen PC?
      The firewire cables and connectors are notoriously flimsy. Make sure you try another cable, and make sure it's seated correctly; don't let the cable hang and pull on the connector, especially at the scanner end.
      • javier4065
        • Feb 2007
        • 251
        scanner is not connected any pc or server, only display says there is not scanner.How can I test the firecables? thanks.
        • Rafael Moreira D'Andrea
          • Nov 2024
          • 10
          i have the same problem, do you fix?
