HP LJ4000N, paper stalls when it enters the fuser for roughly an inch, sometimes two, giving a paper jam indication. The sheet of paper is not at all nicked or damaged. Fuser exit sensor seems to work cause when I manually actuate it it gives a jam indication straight on. Take up rollers and fuser unit are almost new. Fuser rollers seem to nip the paper normally since removal of the jammed sheet needs some force.
Any idea's where to look?
.......and yes, you're right I'm a HP-Noob.....
Hans
Hans
