HP 3005
  • Lotar
    • 76
    HP 3005
    memory failure replace Dimm.
    Ok, replaced Dimm, also replaced DC controller and Formatter! still locks up and gets error. anyone know what the solution is??
    thank you for any help I can get.
    • 23010
    Did you replace the firmware DIMM or expansion memory DIMM? Conceivable either one could cause this error. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      And they are NOT interchangeble.
      • Lotar
        • 76
        i replaced the Memory dimm, -- from what i can see the printer has no removable Firmware dimm, I think once you replace the DC controller it is priority for that printer only.
