Toner compactible?
  • Abimotek
    • Feb 2015
    • 59
    [Misc] Toner compactible?
    Pls HP Toner for model laserjet 1102,2050,4100 and Hp colour laserjet 175mfp,2600,5500above mentioned wish of them compactible with other brand of printers.i wish to know other brand that share same toner with HP brandThanks
  • theengel
    • Nov 2011
    • 1784
    Re: Toner compactible?
    I'm not real sure what your question is.
    • Abimotek
      • Feb 2015
      • 59
      i mean which toner work with other brand like hp,dell,samsung,lexmark etc
      • Itanic
        • Dec 2014
        • 59
        None of them are "compatible" with other makes. Occasionally you will get a rebadged printer which Dell do lot's of but the chip on the cartridge will stop it being used in another manufacturers machine even if it is the same engine. Ta
          • 23008
          I think all toner is compactable. Are you thinking of making toner bricks? It also works well for charcoal-like shading/blending, and like chalk, if you have an artistic bent.
          Compactable dictionary definition | compactable defined
          • Wild Bill
            • Jul 2005
            • 774
            Make sure when compact it you use OSHA certified gloves and face mask
            Izzy
