hp lj600 m603 smear
  • Northwestservice
    • Jan 2011
    • 140
    hp lj600 m603 smear
    I have this smear in the direction of paper travel. see attached (I hope) the customer is using a grained letterhead 6 months ago same problem replaced fuser problem gone smear came back replaced fuser and problem not fixed any help would be nice I hope you can see attachment
    • 22996
    Re: hp lj600 m603 smear
    If you blow up your scan all the way 6400% I think you'll see something like whats in my picture. Essentially there is some sort of lint dragging through the developed image on the drum, or dragging through the transferred, but unfused image on the paper. Lint this small is nearly invisible. Certain Sharp models were prone to this effect. Use a stretch-N-dust to wipe down every surface close to the drum, or near the fuser inlet. =^..^=
    • theengel
      • Nov 2011
      • 1784
      Does it smear on plain paper?
      • theengel
        • Nov 2011
        • 1784
        I kind of doubt that it's lint. The smears are across the board, and I've never seen the lint problem in HP's. I would guess more the paper... at least, that would be my first guess with my limited information. Try running it through tray 1... usually, tray 1 will run at a slower speed. If it changes when you run at a slower speed, it's more likely the fuser. But if it only does it to this letterhead, and not to plain paper, then there's your answer.
        • prntrfxr
          • 1627
          Did you perform a half page test to rule out the cartridge?
          Did you update firmware for the printer?
          Does it happen only on that paper or does it occur with other types?
          • Northwestservice
            • Jan 2011
            • 140
            sorry been busy it appears to be doing it on plain paper as well, the original problem was only the rough paper the inside of printer is spotless clean, did not update firmware I am going to try and get back customer to try a different cartridge
            • Northwestservice
              • Jan 2011
              • 140
              firmware has now been updated Blackcat your sample show white line in black area then black line that follows mine is a black line that follows off the black.
              wiped inside it is now a new cartridge new fixing film and lower rollers and bushings only thing I don't have is a transfer roller ?? now I have reread the help ran paper through tray one (manual feed) and it seems better so will try at customer site with customers paper
              • theengel
                • Nov 2011
                • 1784
                If it's better with tray 1, then it's probably a fuser problem. Replace the entire fuser unit... although, I've been assuming you've tried one or two different ctgs.
                • Printerdude
                  • May 2015
                  • 119
                  Did you tried the print half test to rule out the toner cartridge as stated by "prntrfxr"? You mention you put in a new fuser and replace the fixing film, lower roller and bushings. My guess is you never install a new fuser? Seems like the fuser is the cause of the problem>
                  • Northwestservice
                    • Jan 2011
                    • 140
                    thanks for the suggestions it was a new oem fuser to start with tried a non oem film roller and bushing, tried old and new cartridge, updated firmware, new transfer roller checked laser light path...everything else that has been suggested I tried ..... selling customer a new non hp product
                    • theengel
                      • Nov 2011
                      • 1784
                      I'd bet my right arm it was the fuser.
                      • Iowatech
                        Not a service manager
                        • 3930
                        Huh, I have seen the fuser entrance guide get enough of a charge that it could cause toner scattering like this, but I haven't seen that for some time. Could that be the problem?
                        • prntrfxr
                          • 1627
                          Is there any grease/fingerprints on the sleeve?
                          Sent from my SM-N910P using Tapatalk
